Interesting statement about IMBE
Am I missing something?? It mentions AMBE, the crapola version of IMBE.
N
N_Jay
Guest
The AMBE chip-set does IMBE also.
AMBE is the more generic name.
For some reason P25 is referred to as IMBE, but DVSI does not seem to draw that distinction.
Wonder if it is some "licensing" issue to separate the license for P25/IMBE from the license for other AMBE vocoders?
It's not crap. It's "New and Improved" (TM). Seriously, the AMBE chips & software have the option of backwards compatibility with the older IMBE format. If you open up a P25 capable radio - don't be suprised if you see an "AMBE" stamped chip inside.
-rick
10-95
I was not aware of any compatibility between AMBE and IMBE. Does this mean that the AMBE gear out there can decode IMBE or is there a firmwware issue involved?
The answer is "it depends". For gear using an AMBE chip ... the AMBE 1000 chip supports the 4400 bps / 72000 bps raw / FEC bit rates of IMBE as drafted into the P25 standard. The AMBE 2000 and 2020 chips are backwards compatible with the AMBE 1000 chip. However, the host hardware defines the chip's specific behavior. Ditto for a software codec where the vendor has disabled unwanted functionality.
-rick
mancow
N.E. Kansas
Interesting, this is the stuff that takes forever to dig up when you go looking for it.
I had no idea that AMBE was backward compatible.
N
N_Jay
Guest
AMBE is NOT backward compatable. The CHIP is!
