plutonium233
- Joined
- Mar 31, 2008
- Messages
- 59
- Reaction score
- 2
Good day all,
I've had Proscan set up for three years on a computer that rarely get's used for anything else. It is set up for Web Server and Recording. For some reason in the past several days, I have noticed that I have some type of stuttering in the recording audio and it seems to be totally random. I have a BCD536HP connected via WIFI. The computer is a Dell Optiplex 760 w/ Core 2 Duo E7400 and 2GB Ram. Operating system is Windows 7 Ultimate.
So, I decided to use the monitor and test tab to troubleshoot the problem. When I select "Tone on capture side" and enable loopback, I can hear this stuttering even though the program is playing a simple sine wave. The problem seems isolated to Proscan because I can pull up any number of audio sources including videos on youtube, local sources, etc. and I don't have this problem.
It sounds sort of like what you would expect when you have some external radio interference (like a cell phone too close to amplified speakers or something similar). I turned off my ham radio, my cell phone, and several other nearby devices, but nothing made a difference. I shut down all other programs except Proscan and it didn't make a difference. The only thing that seemed to help was to reboot the computer. It made the situation better, but it is not totally eliminated.
Any ideas on what I could check?
Edited to add: Even before the stuttering issue, I also started noticing that Proscan (latest version) is using more processor time than normal as monitored using task manager. It swings between ~10% and ~50% all of the time whereas in the past it seemed to linger at a constant value around ~15%.
Best Regards.
Best Regards.
