Intermittent Sound Problems - XG-100M/CH-721
AF1UD
I recently installed a XG-100M with a CH-721 (MA/COM). Sometimes when I boot the radio up the volume stays stuck at 20. Other times after a few seconds longer the volume knob has control over the sound.
Does anyone know why this is happening? It's driving me absolutely crazy trying to figure it out.
Thanks!
prcguy
Thanks!
The control head probably needs a firmware upgrade.
AF1UD
Ok. Where can I get the latest firmware?
AF1UD
Thanks Merlin!
Do you also happen to have instructions on how to update the heads firmware?
AF1UD
Thanks Merlin!
I upgraded the firmware but the sound bug problem remains....
AF1UD
I hate to keep bumping this post. I switched control heads and the problem went away. ? Dead or bad MA-COM CH-721...
BMDaug
I am licensed…
Central Colorado, USA
Sounds about right. It may just be the volume pot… as the resistive coating that the wiper contacts wears, it may present a more constant resistance than when it was functioning to spec. This can result in a particular volume being selected over the entire range of the pot. It surely can be fixed, I wouldn’t put much effort into it given the cost of 721s these days.
-B
Teotwaki
SoCal
Did you try opening up the control head and spray cleaner into the pot?
96cf12b9-1b97-4fec-8344-30502a0f56cb
