Hello - your always polite so here is a small bit I will share;
1. A 30kHz (+/-15kHz, 38.4kS, 16bit) wide I/Q bandwidth can now be recorded on the SD card, and played back on a PC with SDR#
2. Addition of a recording type selection in the CONFIG MENU. You will be able to toggle between AUDIO, DISCRIMINATOR, I/Q. There is no longer any need to add a DISC.txt file into the SD card to initiate a discriminator recording.
3. To differentiate recording types, recording file names will start with 0 (zero) for audio, D for discriminator and Q for I/Q.
4. A new system recovery download utility in case firmware updating has issues and procedure or keyboard locks up.
5. Shorter descramble time for NXDN
6. SCAN/SEARCH in NXDN mode will wait to resume until the scramble code is found
7. Improved NXDN detection rate during SCAN/SEARCH
NOTE: Just keeping my relevance for the haters....will share more when I can.
Make no mistake, AOR are doing all possible to get things on track for the DV10 - we all want that to be the case no matter what rubbish is said in this thread about my posts.
