I will give that a try. Thanks for the info and I will report back once I have tested it.
You need to test at both HF and UHF, without test equipment you may find it difficult to measure.
The radio has one master tuning adjustment in the service menu, it doesn't seem possible to get the frequency correct for both the 100k to 76MHz and 76MHz to 1300 MHz ranges.
Best way to test UHF without equipment and 70cm beacons nearby is to test on an analogue FM signal with 0.1kHz steps and 6kHz filter like this:-
This test needs to be done when the radio is cold and when its hot (on for at least 1 hour).
1. Find a signal in the UHF Band 400MHz upwards
2. Put the DV10 into VFO mode A, B or Z doesn't matter which one.
3. Open the squelch, NSQ or LSQ to 000
4. Set the Mode to FM
5. Set the IFBW to 6kHz
6. Set the step to 0.1kHz
Tune the radio up and down slowly until you find the 2 points where the noise increases significantly.
As an example, if you listen to a signal on 450.000MHz the noise should significanly increase above 450.00310 and below 449.99690, ie 3.1kHz either side. Any different offset than +/- 3.1kHz is the frequency error, repeat the test at switch on and after warming up for an hour, any difference is the drift.
