Hi all
So I am currently working on creating an inverted v with a total length of 120 feet of insulated, stranded 12 gauge. In the center I would like to use 450 ohm ladder line to the tuner. My intended use is for 80,40,20,10,6
There is approximately 75 feet from the center of the inverted v to the manual tuner (mfj-945e). The tuner has so239 connector.
Where in the v to tuner section should I convert from the 450 ladder to the RG213? Should I use a 4:1 balun at that connection?
Or should I just have the balun at the inverted v center and forget using the 450 all together?
Regards
Regards
