Iowa State Patrol aircraft on tar1090.adsbexchange
@mws72 using the /?icao= will work, and shows the last position of the aircraft in the previous 24 hours if not currently in the air, but if you use /?icaofilter= it will bring up just the live tracking.
mws72
Quad-Cities (IA-IL) USA
You might want to add N618GL to your MEDVAC tracking. It's the Gundersen Lutheran EC45 based out of Decorah (KDEH) and usually makes at least a couple of flights a day.
I had seen that at times, I had found it from Gunderson in LaCrosse. So it is forward base in Decorah like the Aircare 2 & 3 are in Waterloo & Dubuque?
w0fg
Decorah, IA
Yes. 618GL is hangared here in Decorah about 2 mi south of me. They also have a bird based in LaCrosse, and I believe another one somewhere else in WI. They just landed about 15 min ago on a flight back from Mayo in Rochester.
