Iowa State University TRS
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
I was looking at the database entry for for the Iowa State Univ. TRS, and I noticed that there is no longer a valid FCC license for this system. However, I do see a valid license for the ECC TRS, DBA: Ames, City of. Can anyone tell me which frequency list is the most accurate? I take it that both the city of Ames, and Iowa State University, are one in the same?
I see that each listing has a different Motorola System ID, can anyone verify which one is correct?
Thanks,
Ron
burner50
The Third Variable
NC Iowa
Thanks,
Ron
AFAIK they are still on separate systems... As far as valid Licenses, it appears that Electronic Engineeering holds the license for the ISU system. Peraps they lease a repeater?
n2mdk
Ames, IA
They are 2 seperate systems but Ames and ISU have a few TGIDs on each others systems. Both systems are owned by Electronic Engineering. Since the systems are leased there are commercial users as well as municipal and ISU on them.
Here are the frequencies for both systems
ISU
0859.5625 Primary
0860.5625 Primary
0857.5625
0852.3375
0853.2875
0853.7375
0854.7375
0855.6375
0856.0125
0856.5625
0857.0125
0858.0125
0858.5625
Ames
0852.3375
0853.2875
0853.7375
0854.7375
0855.6375
0856.0125
0856.5625
0857.0125
0857.5625
0858.0125
0858.5625
0859.0125 Primary
0860.0125 Primary
0855.1625
0854.0375
The primary control channels alternate on a daily basis and switch over at midnight.
iascanguy
Des Moines
Almost all of the frequencies in the database listed for the system used by ISU belong to the system used by the city of Ames. There are only a couple from Jerri's list showing as being used by ISU. Jerri, maybe you could submit the correct ones for ISU?
Donald
n2mdk
Ames, IA
I have to double check the frequencies and see if there all correct, I took them from my BC780XLT.
