I have a 20' metal carport with 6 metal legs buried 2' deep. I've added a ground rod. I believe it's a good platform for 3 antennas on the one side which is free of trees.
I already have a 60cm antenna up there on a 10' pole. and I plan a 2m antenna on the same setup next . Each will be 10' away from the other, even when I add a third.
Do you believe that 10' is sufficient spacing?
