darticus
Could use some input about D STAR. Thinking of buying a radio with D Star but trying to learn something about it first. Thanks Ron
Ron,
From the several posts you've made in various threads it's apparent that you are new and/or newly licensed. Before you commit to D-Star, P25, TRBO, or any other digital mode you'd probably be better off getting your feet wet, so to speak, by just operating FM analog and finding out how things work. The D-Star equipment is not cheap, to start with, although the radios do include analog FM as well. The other consideration would be your local D-Star situation, or put it another way is there enough activity to justify the added expense of a specialized D-Star transceiver?
Uh, yeah it is. In most cases you need to double the cost of a regular radio to go D-Star.He said it wasn't that much more money to get started.
It sounds to me like D-star is more for data transfer than for QSO's, is this correct? Also, is D-star an open system, or do you need another op's code to talk to him? Looks like the equip is pricey, too. I saw an ICOM 2m 65watt radio for $169.00. To make it D-star compatible, you need to add a 199.00 D-star board. I don't know if I really see the advantage of this unless you are into sending data over the air, but even then there are other non-proprietary systems to accomplish this which likely have more users.
I wouldn't recommend that you go DStar if you are a new ham. There is plenty of time to do that in the future. :wink:
DStar is complicated to setup and I think that you should get your feet wet before you step into something that is complicated.
