I would contact the building department, as this is subject to local regulations AND Electrical Code..I was thinking, my neighbor won't allow me to run my dipole to her tree so would it be legal to run from my 40 foot tower across the street to the other neighbors tree if they gave me permission?
Best to check with your own town or city's building codes, by laws, etc, rather than opinions from here. That being said, I wouldn't do it even if it was legal.... you would be opening yourself up to a whole new world of liability issues should something of yours fall and hit someone traveling on a public roadway.This might be a stupid question but...I was thinking, my neighbor won't allow me to run my dipole to her tree so would it be legal to run from my 40 foot tower across the street to the other neighbors tree if they gave me permission?
I thought same thing, it was a think that crossed my brain so figured wth put it out there so for others if they get the same think as me lolBest to check with your own town or city's building codes, by laws, etc, rather than opinions from here. That being said, I wouldn't do it even if it was legal.... you would be opening yourself up to a whole new world of liability issues should something of yours fall and hit someone traveling on a public roadway.
If done to code, little chance of falling down? Utility lines fall down frequently even done to code. Ice, wind, tree limbs falling across them.You should be able to do this legally and your local city building code people should be able to point you to the requirements. Most public roads have easements for utility wires and services and you would probably be crossing over that. Once you understand what is required you might have to make an appeal to the board that reviews this kind of thing and present your case and how it would be accomplished while meeting code. None of this should be a big deal, it just has a procedure and you just need to understand what that procedure is.
If you get it approved you would have to adhere to code and if its done to code there is little chance of anything falling down or getting snagged by a passing vehicle. Things like this are done everyday somewhere and I work with people that do these types of things. One guy I consult for needed a huge power pole moved on his property and the local power company was not moving very fast. The pole had problems and was tagged for replacement and he had done construction on his property making use of the old pole location. This was a huge pole with very high voltage stuff on top.
My friend finally got fed up with the new pole laying on his property so he dug the new hole with his own heavy equipment and got a huge off road fork lift with pole grabbing attachment and set the new pole in per code. Then he notified the power company of what he had done and they finally got off their a$$ and transferred all the wiring and services to the new pole set by the home owner.
There is usually a path to get most anything done that you can come up with.
Pretty much my thoughts to.its a bad idea all the way around, you will be better off staying within the property lines of your property that way if something would happen you wouldnt have opened a can of worms that you may regret.
