Is it likely my SWR meter is wrong? Opinions
FPR1981
Yes, the home-made approach is definitely an option--good learning experience and satisfaction with doing it yourself. Although lacking a machine shop, I'm not sure how the efficiency/quality compare.
Thirty dollars might seem like a lot of money, although with antennas being the most important part of any radio set-up--and compared to the costs of things like beam antennas and so forth--it might be money well spent.
I've kicked around the idea of buying the Deluxe 11 meter dipole with the balun, good wire and insulators for 49 bucks just to compare performance to my own builds.
FPR1981
Talked in town to the target base station last night successfully! Not only that but I talked to my son for 4 miles in my mobile. He was using the new antenna. My mobile is totally barefoot.
FPR1981
You put the research and effort into it and came up with the solution.
Good job
Thank you. It required starting from scratch and re-tracing steps based on what the science said, but I put in the work and made it happen. It took a total of three installations to get it right, and I went through a lot of zip ties in the process, but I got it.
I forgot my roll of 12 gauge wire in town so I had to improvise. I had dual 18 gauge speaker wire, and that's what got used. As soon as the weather is better, I'm going to re-make it again with better wire.
Speaker wire works, though, and decently well.
I'm also heading to lowes to buy a PVC pipe and caps so that I can build a balun. My research suggests that I can do it with 18 to 21 feet of coax wound around the pipe. That'll be my next project. I will be curious to see if a balun improves antenna performance in a way that I can distinguish.
