Hello all!
tl,dr: My circa-2017 RTL-SDR stick has been running well under OP25 since fall 2019 with a +400 Hz offset. A couple of weeks ago, the +400 Hz offset stopped working very well; I changed it to +1200 Hz and it works better. Is it normal for the "best" offset to suddenly change like that?
I bought an RTL-SDR stick around 2017. I played around with it when I first got it, listening to various things. I didn't have any P25 software for it, so I eventually put it back on the shelf.
A couple of years later, I got it down again, and set about getting OP25 working. At first I didn't understand how setting a tuning offset would help; when I started OP25 with a 0 offset, I would hear traffic, but after a while it would die down. After a few weeks, I figured out how to use the plots in OP25, in particular plot 5, "mixer balance". I got the best results (numbers closest to 0) on that plot with a +400 Hz offset, and if I set that as soon as I started OP25, I could let it run continuously and not suffer a loss of traffic. I let it run that way, more or less 24/7, from fall 2019 onwards.
A couple of weeks ago, I had to restart OP25 on my PC. I did so, applied the normal +400 Hz offset, but wasn't getting much traffic. I eventually pulled up plot 5 again and noticed I had rather higher numbers for "mixer balance" than I previously had, like 80-150 or so. I played with the tuning and an offset of +1200 Hz got the mixer balance back down to 0-30 or so, and resulted in a steady flow of traffic.
The thermal environment for the stick hasn't changed much. I have a USB hub with about a 2 foot cable plugged into the back of my PC, and the stick plugged into that hub. It's sitting on the desk behind my monitor. I run the furnace in the winter and the A/C in the summer, and the stick has been through a couple of seasons now, without needing a major tuning change.
As far as I remember, I haven't dropped the stick, or dropped something on the stick, or otherwise given it a mechanical shock. There wasn't a thunderstorm or power outage or something that would tend to feed it a voltage spike around that time. It just suddenly wanted a different tuning offset one day.
Is that normal? Or has something odd happened to my stick?
Thanks!
Papagei
Thanks!
Papagei
