Is it possible to clone or copy the codeplug from one CDM1550LS to another radio?
JoshuaHufford
Jefferson City, Mo
I would like to program a second CDM1550LS exactly as I have one now. If I try to load my saved codeplug from another radio it gives me an error code that the radio information doesn't match. I don't see an option anywhere to clone the radio either.
Any ideas or workarounds?
Thanks.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Sorry, but no. If the model numbers are not identical you’re out of luck. If the model numbers match, there may be a discrepancy with Tanapa or firmware. The Pro CPS doesn’t accommodate copy and paste either.
These are known and well documented weaknesses with the Waris software and have been discussed many times here.
Yeah, it'll work but ONLY if the model numbers are 100% identical. If they are not, it will not let you clone the file over.
In other words, get typing….
