Is it possible to use TMS radio to radio instead of with a server system?
riveter
MD
We talking DMR or P25? Didn't see any specifics.
Don't think P25 has any direct message functionality, as far as I've learned, everything has to go up through the RNI and out the PDG to a server for it to be effectively processed and routed to the target terminal.
However, I've done it with XPR7550s in DMR simplex and repeated duplex, so it does work with those in DMR.
gatekeep
FAIL 01/93
New York, NY
I'll make the dangerous assumption that your referring to P25 radios.
TMS on the ASTRO25 platform unit-to-unit on talkaround without P25 infrastructure is absolutely possible (infact the non-infrastructure method also seems to allow the TMS data to flow across a P25 conventional repeater as well, assuming that the packet data mode is "Repeated" vs "Direct").
For direct:
  • On the radio wide options, "General" tab, ensure that "ARS User Login Enable" is checked, and a Soft ID/Username and PIN are set.
  • On the radio wide options, ensure the radio has unique IP address(s) set on the Data tab.
  • On the ASTRO system "Data" tab, set "Packet Data Mode" to "Direct".
  • On the ASTRO system "ARS" tab, ensure the checkbox enabling ARS is checked, and set the "ARS Mode" to "Non-Server".
This /should/ make TMS work direct over talkaround.
beaker7
Boise, ID
For direct:
Ok so if I do this I could send text messages to other radios like XTS3000 radios and newer?
gatekeep
FAIL 01/93
New York, NY
XTS3000 and ASTRO Saber do not have nor support text messages.
This will work for ASTRO25 radios (i.e. XTS2500, XTS5000) and newer.
riveter
MD
For direct:
Hey, I didn't know that. Writing that one down- thank you very much, I learned something today.
beaker7
Boise, ID
Ok, very nice I will look at getting another XTS 5000 to test this out. Thanks for the help!
