Is it possible?
pointman1177
Metro Detroit, Mi
Okay in my part of michigan almost all of the local police departments around here have switched over to the dark side of digital communication. I have an amateur tech license and have a friend who is good at programming motorolas. My question is this....
Can I get a motorola astro and program it to recieve only most of my local PDs on the digital apco 25 800mhz system? is it feasable within reason? I want a budget digital scanner with the output that only motorola has.
Can I program it with RSS?
does anyone have this kind of setup I am anxious to hear about the possibilities. I think it would be a great experience to do this.
Thank you in advance!
W2NJS
Washington DC
Unless you have the system key, which the agencies will not give you, you can't receive trunked digital transmissions by their particular talkgroups. You can do it by using a digital trunking scanner, however.
pointman1177
Metro Detroit, Mi
thank you for the responses and I am sorry to have basically double posted I had tried to find evidence that someone obviously thought of the concept years ago but apparently didn't look hard enough.
Thanks again
KG4INW
Midlothian, VA
Hey no problem, it's very logical to want to use commercial radios for their advantages but it's really tricky, as you'll read.
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
"Dark side" of digital?
A GRE scanner does fine with MPSCS. Granted the PSR-800 handles simulcast areas better than the 500 or 600, or their RS clones. The scanners also allow a much larger scan list, as others will have noted.
