Yes frequency is within the scanners receive range. How well the 996p2 work in your new simulcast situation will depend on several variable. I use multiple 996p2 in a heavily simulcasted system with no issues. Others do not have the same success.My county sheriff's department has gone to a simulcast system on frequency 770.46875c. Is a BCD996P2 capable of being programmed with that frequency? Thank you for any assistance you might be able to provide me.
Your 996P2 is capable of receiving that frequency, so that alone is a non-issue.My county sheriff's department has gone to a simulcast system on frequency 770.46875c. Is a BCD996P2 capable of being programmed with that frequency? Thank you for any assistance you might be able to provide me.
If the location in your profile is correct, this is the map for the site you are listening to:Yes frequency is within the scanners receive range. How well the 996p2 work in your new simulcast situation will depend on several variable. I use multiple 996p2 in a heavily simulcasted system with no issues. Others do not have the same success.
Iowa Statwide Interoperable Communication System (ISICS), RFSS-2(2), Site-019 (13) , Name-Chickasaw Co Simulcast , County- Chickasaw Co., Frequencies 769.71875, 769.96875a, 770.21875a, 770.46875c (primary). Does FreeSCAN have the correct software available?Your 996P2 is capable of receiving that frequency, so that alone is a non-issue.
More important, though, is the simulcast system. Simulcast distortion (on a scanner) is extremely location driven. If you are very close to one of the transmit towers, say a quarter mile, the very strong signal from that transmitter might drown out out of sync signals from the other sites. Or, if you are far enough out of the center, or can use a directional antenna to focus on only one transmitter, your scanner might still work. In some cases, using 'less' antenna, even only a paperclip, might help, and at times, using the attenuate setting can also be of assistance.
More on Simulcast can be found in the Wiki.
Simulcast digital distortion - The RadioReference Wiki
What system, and/or site, will you be trying to monitor?
I am in concord, but I have a large external omni antenna outside as well as a yagi that I switch between. I also have a 50ohm dummy load that goes into the rotation as needed. I also have a 996p2 set up in my office near UNC Charlotte. The 996P2s have done well for me but I know how to compensate when I am getting an overload. I have an SDS 200 sitting with one of my 996P2s at home and they operate nearly identical other than the 996 has a hotter receiver. I could however tell the difference between the 996p2 and the SDS200 and unication G5 in my truck as I traveled and i do not have the luxury swapping antennas as I drive...at least no safely.If the location in your profile is correct, this is the map for the site you are listening to:
In your case, Concord is very close to one site. That strong signal is likely drowning out conflicting signals from more distant ones.
Simulcast is making everyone's scanners obsolete, unless you own a Uniden Super Duper Scanner 100 or 200
Thankfully I have almost no simulcast in my area, and in fact the change from analog to digital has been at a snails pace thankfully. I still use my old analogs like 246T, PSR-300 and my favorite 346XT nearly daily. When analog hits extinction levels here (it's only a matter of time) I plan on keeping the 346 running for air band. It's just too good of a radio to let go ofNot in all cases. They work great with simulcast in some circumstances for some people. I'm one of them, and I have a SDS200 to compare it to.
