is my radio bricked?
rjvalenta
i got my hands on an old XTL2500 with an M5 head, very standard... and had read online that i could use depot to put an XTL5000 codeplug it it for more channels, so i created said codeplug and push it into the radio... and didn't notice the codeplug i'd made is for a W3 control head.
now the radio is stuck in Maintenance Mode Remote Device - or Maintenance Mode Local Device when i plug in the programming cable.
when connected to the computer, it will not respond to any attempts for CPS to program it. pressing the home button 5 times does nothing, it will not enter service mode.
THE QUESTION: if i connect at PMLN4959A cable to the back and a W3 head, will it likely start and allow me to reprogram it?
if not, anyone have any suggestions?
clbsquared
Isle of Wight County
Your only option at this point is to obtain a rear accessory programming cable. And write the correct codeplug to it. Assuming you used the software we shan’t speak of. If you didn’t , then follow the above instructions. Throw it away and get another one or find someone with the correct tools and know how and give it to them.
rjvalenta
i need to make a rear programming cable to connect to the DB9 i have for my XTS... anyone know the pinout?
wgbecks
NE Wisconsin
You'll have to restore the radio back to an XTL2500 until such time as you either modify your existing M5 to a 05 Control Head or that
you exchange the M5 for a 05 Control Head.
Building a programming cable to attach to the J2 Rear Accessory Connector is not difficult, but obtaining the correct pins and
crimp tool is more problematic. Nonetheless, here is a wiring diagram that provides both Serial RS-232 and USB options.
Note that you may need to include the Ignition sense lead as well for some applications.
rjvalenta
so i learned something through all this - and so... FIRST - thank you to everyone for your help.
through this i learned that if the radio thinks it has a W3 head, you can only program the radio from the rear J2 port.. which required me to use a staple to connect 14 & 15... then use the above pinout to connect a DB9 breakout box to back of the radio. a friend of mine had some J2 kits, but he is out of town, and i only needed this to work for the time it took to get the right code plug back in place, so i stripped a piece of cat5 and taped everything in place and got it to work.
again, THANK YOU to those who helped me learn something and get this fixed, i hope posting all this helps the next person who makes the same mistake.
a417
You know what also works quite well? The jumper wires that get used with breadboards. They fit snugly in the pins, and they don't require tape. The cheap packages are only several bucks for a hundred or so, and if you have a breadboard with a breakout for serial (like I have), you don't even need cabling for various serial based radios.
WB6WQF
Sacramento, California
Remember that the head is an accessory and the brick needs to know what is attached. You are good from the rear until you figure out the front.
