Is the a way to access RR database to
grosema
Near Sarnia
With RS Pro 96 & Win96 Just to put in Common frequencies Like schools, events, fast food drive with out having to put them in all by hand manually one at a time. :?:
TIA
grosema
Near Sarnia
I guess that is your final answer. That is What I thought.
That is the same as Manual :D
hulka
Laveen, Az
No, cut & paste is a lot less time comsuming that manualy typing in all the info. Not the fastest but it does work!
Kevin
rescue161
KE4FHH
Hubert, NC
A whole hell of a lot faster than putting the frequencies in from the front panel of the scanner... :shock:
I'd be thankful just to be able to type the info in on a keyboard versus punching in the info via the keypad on the face of the scanner...
Cut and Paste? My God, how freaking hard is that? No where near as a pain in that ass as inputting all the info "manually"... Yeah, that means putting it in via the keypad, hence - No computer involved...
Voyager
TIA
You can use the new import feature if you are a paying RR supporter.
Joe M.
grosema
Near Sarnia
Voyager
I am a supporter to RR
Can you explain to how to put them in :oops:
I have put in frequency's For Police and FD through File import web / but the common ones and phones I cant figure out how to get them in via the software win96
scannerfreak
Well Known Member
Indiana
In WIN96
Go to
File>Web Import>Radioreference.com
Then sign in with your rr.com user name and p-word.
grosema
Near Sarnia
I do that to get the police and fd and RCMP but not good for telephones and common files you cant get to them at least I cant :roll:
hulka
Laveen, Az
You high light the freq you want, right click mouse, select copy and then paste it into the program. lot easier than typing in manualy through keypad. Not to hard really. I did that a lot before the RR web import feature.
grosema
Near Sarnia
Thanks Everyone I guess it the old copy & paste maybe it will happen in the next version??? win96 v102
loumaag
Silent Key - Aug 2014
Katy, TX
Voyager said:
TIA
The web import feature only works with trunking systems. No conventional, and certainly no common frequencies.
For that matter the common frequency lists are moving to the Wiki and are not part of the database at all.
