Is the DMR firmware available on the web the same as Whistler will put on for 59.99
KC2OVX
I see there is a series of firmware upgrades that allows you to update the pro 668 to be a PSR 800 and then you can load the Whistler WS 1080 firmware onto the radio but not the most current firmware there is something about a warning that you have to use a modified version and you can't update past a certain date.
Is the firmware that Whistler will put on the newest firmware or is it the same as what is available on the web to do yourself ?
Does anyone have the official updated firmware that Whistler puts on the pro 668 to update it to receive DMR ?
Does the official upgrade also give you NXDN ?
Bill
tvengr
Well Known Member
Baltimore County, MD
The official upgrade gives you DMR only. No NXDN! It also adds P25 Phase 2 to the Pro-18. If you use the firmware on the web, you may brick your scanner. It will also cost you more for the upgrade. The Whistler Legacy Upgrade converts the PSR-800, Pro-668, and Pro-18 to a Whistler WS1080. You will use the WS1080/WS1088 EZ Scan software for firmware, library, and EZ Scan application updates. I have seen many reports of improved performance after the upgrade.
KC2OVX
Can you get the full keyboard front plate added for an additional fee ?
HWG
Southeastern, OH
"Is the DMR firmware available on the web the same as Whistler will put on for 59.99"
Unfortunately, prices for the upgrade have been increased by $10:
Units free of operational defects will be upgraded to the authorized Whistler DMR - $69.99
Units operating with unauthorized firmware will be upgraded to the authorized Whistler DMR - $99.99
Units previously not eligible (not fully functioning) for the authorized Whistler DMR update will be repaired and upgraded to include the authorized Whistler DMR - $129.99
