Is the MTS2000 narrowbandable?
Nasby
Ohio
I've read and heard conflicting answers so I thought I wold ask here.
Does the MTS2000 version 1 (the 48 channel version with the top LCD display) "BN" serial number, meet the FCC narrowband requirements?
Many thanks in advance.
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
Not sure if the "BN" models are narrowband-accepted but my MTS2000 with full DTMF front pad along with my MTS2000 UHF top LCD is narrowband-accepted...With that in mind I'd assume, until said otherwise your radio is good.
Regards,
-Frank C.
DPapay
Morris County, N.J.
I have a UHF BN model right now that I program using the windows cps. It is 12.5 khz channel spacing capable. I am also looking at a UHF AN model codeplug from the DOS RSS, and in the option section for each channel, I am able to select 12.5 khz, so I would say that the MTS2000 model is narrowband capable. Good Luck.
mfire39
Astroland
What you can select in a codeplug vs what you can actually write to the radio are two different things. The radios firmware version will dictate whether or not it will take a narrowband channel upon writing. You'll get the error that says "This radios firmware does not support 2.5 channels, please upgrade the radios firmware".. With the MTS, I think it was firmware in the mid to upper 5's that started narrowband. I know for a fact that firmware R06.00 supports it.
