Is the NMN6271A RSM Better than the rest?
Rlahey
Sunnyvale Trailer Park, Dartmouth, NS.
I see a large number of public safety agencies choosing the dual mic/dual noise canceling NMN6271A RSM over the cheaper single mic/noise cancelling RSM's. Is the NMN6271A actually better than the rest? Or are the salesman doing a good job selling a more expensive RSM...
BlackSheepDue
Naples, ME
I don't have any experience with the NMN6271A but I use the PMMN4106 and the audio quality is well worth the price in my opinion. Much clearer and significantly louder. It also has programable buttons, volume adjust, and a channel selector. I also think my transmissions are clearer in loud environments than a regular mic
redrock2002
Ok so dumb question probably...
These are for apx radios i know that. Can a XPR7550 interpret the extra mics ports? I work in an extremely loud industrial environment and I know the connector to the radio is the same but idk if the xpr codeplug can utilize the extra features these mics have for my use case scenario.
K2NEC
I will say I have noticed better audio with the mic, both transmitting and receiving, and it does better in loud noise environments.
Yes the XPR does just fine with the mic, there are 2 versions of it however. The mic with the 3.5mm port on the connector is specifically made for the APX and will NOT fit the XPR series radios. Furthermore, the mic will only work properly on gen 2 radios (XPR7x50, etc.)
NVAGVUP
When purchasing RSM's for our rural fire/EMS, I evaluated all models from the basic version to the XE. (They are connected to APX4000's)
The 6271 does not have 3.5 mm jack, which enables an IP68 rating for moisture. The audio performance was top notch under varied conditions. Additionally these folks are volunteers and they do not like the bulk of the XE model. (Especially the EMT's) This RSM has proven itself. Here is a pic of a ff during a blizzard/interstate pile up. You can see video of how bad it was and they had NO communications issues in those conditions.
redrock2002
Yeah we would have to have the 3.5 jack for our earpieces. We use the 4050 noise canceling mics currently with a lot of success but some folks just can’t be bothered to tip the mic and talk into it so I was looking to see if these other ones with top mic ports would work.
