is the pro reflashable
mikeh
fremont calif
so what is the story i get 12 storys is the pro96
reflashable when reband goes down.
will my 96 be able to do the new band set up.
Al42
Long Island, NY, USA
That depends on how Motorola implements rebanding. No one can tell you until the first rebanded systems are on the air.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Al42 is correct.
However, re-flashing may not be required with the 96/2096 because these scanners may be set with up to 6 extended tables using Win96. These settings should allow the new CC to find the new VC's.:)
Voyager
fmon said:
Al42 is correct.
While I agree with all the replies thus far, the answer to the original question is:
ONLY the DSP can be flashed. The CPU msut be replaced to upgrade the CPU firmware. That requires a trip to Fort Worth.
Joe M.
