Is their a limit to having groups in systems?
MichaelC34
Boston, MA
472.41250 WIH765 RM131.8 PLLynn PDPolice Operations FMN Law Dispatch
Is the mod supposed to FM for that for NFM? I usually can hear this channel on my other radio but for some reason i can not hear anything
ProScan
Software Provider
Ontario, Calif.
472.41250WIH765RM131.8 PLLynn PDPolice Operations FMNLaw Dispatch
Change it to FM and see if it improves. If you change it at the scanner then at some point, you should download the data from the scanner to ProScan so everything is in sync. If you change it in ProScan then you can right click that channel in the tree and choose "Upload Selected Nodes".
MichaelC34
Boston, MA
I just did that but it's still not changing to FM
MichaelC34
Boston, MA
its wierd because i can hear other departments further in proximity and i usually pick them up with my other radio but they do come in muffled up sometimes
wtp
Port Charlotte FL
there are many variables.
their antenna height, power output, directional antenna? antenna angled down. hills in the way.
and then even your radios one might do better on some frequencies or bands than the other.
even which way your antenna might be angled a bit.
JANFINE
MIRAMAR, FL
Although 1000 channels per group is advertised I can tell you that it is not correct.
I have groups with over 2500 channels in them. When using software to program I get an error message.
But all freqs get programed and read by the software.
ProScan
Software Provider
Ontario, Calif.
What type of scanner with 2500 channels in a group? I did a test just now using a BCD996P2. I uploaded 1000 conventional channels in a group. No errors. Then I manually tried to add a channel and got an error on the display "Over Limit". Any errors seen in the software are generated by the scanner. Sending the protocol command ACC (which appends a channel to a group), the command will either be accepted or return -1 which means the scanner failed to create a channel because of no resources.
JANFINE
MIRAMAR, FL
I have both a BCD996P2 and the BCD325P2. Same with both. I have over 2500 freqs in a few different groups. Although the software will respond with an ERROR message it will program and read with no problem.
ProScan
Software Provider
Ontario, Calif.
I see now. It's not an error message but a info message. I'll change that.
