Is there a driver available for Window 11 ARM processors? PD782i. CPS.
rick25s
I just had to replace my Mac, and realized right away that I had to create new VMware virtual windows machines with the windows 11 ARM version. None of the radio drivers I have work in that windows version...at least I can't get them to work.
The latest driver I have is DMR_SW_usb driver V5.30.42.0_64Bits, but I suspect I need a different one altogether. I'm betting Hytera doesn't make it...yet, if ever.
Has anybody been successful in getting the driver to work on a windows ARM machine?
rick25s
Update: I'm on the right track with building and compiling an ARM driver, but ran into a Microsoft roadblock...no surprise there... There is a problem with the WDK (VS 2022 Extension WDK - Windows Driver Kit). The actual package built for the ARM processor only references amd64, which causes the install to fail, due to no supported architecture. Changing the references from amd to arm, allows you to successfully install the VS2022 WDK extension, but then launching VS2022, it detects a digital signature mismatch (installer package checksum - because of the extension.vsixmanifest adjustment), and will not allow the extension to operate. Even after completely disabling signature verification, the results are the same.
This is typical Microsoft. They screwed up the WDK build, and refuse to admit there is something wrong with it, even with glaring evidence that the ARM targeted extension is missing a target reference to the ARM architecture.
Existing config:
<InstallationTarget Version="[17.0,18.0)" Id="Microsoft.VisualStudio.Pro">
<ProductArchitecture>amd64</ProductArchitecture>
What it should be:
<ProductArchitecture>arm64</ProductArchitecture>
