I have an XL-185P with a scan front cover. I want to upgrade to a system (full keypad) front cover on it.
I found a compatible system front cover for it, for a mere 75 dollars (well under the usual 338 dollars) but knew from the start that the
top LCD is broken in it. The front cover is otherwise in perfect, new condition.
Upon close inspection I think that the LCD got damaged while the cover wasn't even attached to a radio. Somebody was playing with it
and pried at the LCD, trying to see what held it in place (there is no visible hardware holding it) and in doing so, snapped it in half.
The top LCD (in fact, neither it nor the front LCD, or any other parts on the front cover assembly) are formally considered replaceable.
They're not shown as replaceable in the service manual.
But by some careful inspection and prodding, I was able to figure out how to remove the top LCD. It is simply held in place by an adhesive gasket,
with adhesive on both sides. It's a strong adhesive.
All I would need in order to do the repair is to obtain the replacement top LCD and the accompanying adhesive gasket.
The most time consuming part of the replacement process is just getting small tools into the recess where the top LCD sits, and digging the little
chunks of broken glass out and getting out the residue of the gasket as well. Which does take a few minutes and good eyes. But it's not a job
that's above the skill level of anybody who has any business working in a radio like this. I'd say connecting the mini GPS and LTE and wifi connectors
require similar dexterity or more.
So is there a Harris dealer/service center out there that has enough persuasive ability with Harris to get me that LCD and gasket? Please?
