bsavery
Is there a Moto radio that, when programmed, can access 2 totally different systems? One is a APCO25 9600bd system, the other is a type II. Both are 800Mhz though.
The reason I ask is Omaha's helecopter unit popped up on the Sarpy County system last night and called the Dispatcher directly to report a drunk driver headed their direction. Both her and the Bellevue PD units seemed very suprised they could do that. In the past, they've always had to patch Able-1 in before they could talk.
I suppose they could mount 2 radios in the helecopter (actually 3 or 4 by the time you add in the standard aircraft radios) but I would assume space would be a bit tight to allow that. I'm just wondering if maybe they replaced the unit (or reprogrammed it) to allow it to work on both systems.
Bob
Bob
