Pyr8
Is it posible to scan upper and lower AM sidebands on a BCD996XT?
I take it only strieght AM. Are there any scanners out there that will do AM SSB?
Not that I'm aware of. Several of the communications receivers will do what you are asking but most are not really scanners even though most do have basic scan functions.I take it only strieght AM. Are there any scanners out there that will do AM SSB?
What frequencies are you looking to use an SSB mode?
Scanner radios, no. Wideband communications receivers, yes. However If you aren't prepared to shell out potentially hundreds on a communications receiver capable of receiving SSB (AOR, Icom and Alinco are a few brands that come to mind), perhaps consider a software-defined radio for a fraction of the cost. Only drawback with going the SDR route is you also need to carry around a laptop or tabletAre there any scanners out there that will do AM SSB?
I think there were several models made that could only do FM mode below 30 MHz so no AM for the CB channels if you were into monitoring CB back in the day.Pyr8, your question brings up a good point. This scanner's (and many others) frequency coverage starts at 25 MHz. That covers the CB and 10 meter ham bands (in the U.S.) on which SSB is very popular. Yet the scanner cannot demodulate SSB. Weird![]()
