Sentinel: Is there a way to do a text search of the sentinel database?
pinballwiz86
Missouri
No, your best bet is to get a premium subscription on this website and search for the frequency that way.
Ubbe
Stockholm, Sweden
I have looked around the forums but cannot find if there is a way to do a text search of the sentinel database?
If you go to C:\Users\All Users\Uniden\BCDx36HP\Database
you have the whole database in the text file MasterHpdb.hp1
You can open it as a text file in Notepad or other programs that handles text files and do searches.
If you haven't installed Sentinel for "All Users" it will be under your login name.
/Ubbe
darthgarlic
Queen Creek Arizona
/Ubbe
Thank You I will do that.
ofd8001
Louisville, KY
Just be really, really careful when it comes to editing and saving. There is a certain file structure as in field lengths.
Ubbe
Stockholm, Sweden
Yes, if you also want to edit a text, frequency, TG or service type you can do that but be careful as each data are separated by an invisible tabulator character, so don't mess that up. It's easier if you import the database in an Excel type of program as a tab delimited format and then edit. It will then save back to the same format.
But when edit you should probably not use that file but instead the much smaller ones that are one file for each State. In the beginning of the database file you can see what number each state has, it is also in the hpdb.cfg text file, and that then has a s_0000xx.hpd file that you can edit.
I don't know which file, the hp1 or the hpd, that are actually used in Sentinel for the database. I think it is the hpd file and that hp1 file that have all info for all states are probably for doing compare to database when you do Discovery. Or it is actually the DB file for HP1/2 scanners. But the file has all systems, even the ones the HP1/2 scanner do not support. But maybe it is filtered in the scanner somehow.
/Ubbe
