As posted above, is there an easy way to remove the DMR Time Slot Data from the History Log from either ProScan or ARC536PRO?
The reason for this is I will create lists to scan and when there is activity logged in the history log on DMR frequencies they are logged as:
Frequency with a slash and the Time Slot number, either 1 or 2. I would like to be able to cut and paste those into another file. However, the " /1 " or " /2 " will cause an error.
If there is an easier way to import that data, please let me know.
I could cut and paste from ARC536PRO, but the frequency has MHz following it.
155.505000MHz 155.505000MHz All-None
155.640000MHz 155.640000MHz All-None
161.092500MHz 161.092500MHz All-None
| CC 11 | 453.900000/1 | -127 | NFM | 3 | 00:00:05 | 07/03/24 13:51:16 | 07/05/24 03:46:15 | New System Saved | UHF DCS/DPL Search IDAS | 453.900000MHz | Conventional | CAP | Custom 1 | 0 - 0 - | ||
| CC 3 | 453.725000/1 | -127 | NFM | 1 | 00:00:00 | 07/03/24 22:04:11 | 07/03/24 22:04:11 | New System Saved | UHF DCS/DPL Search | 453.725000MHz | Conventional | DMR | Custom 1 | 0 - 0 - | ||
| CC 9 | 453.725000/1 | -125 | NFM | 8 | 00:00:14 | 07/02/24 21:13:23 | 07/05/24 13:21:34 | New System Saved | Department: 1 | 453.725000MHz | Conventional | DMR | Custom 1 | 0 - 0 - | ||
| CC 11 | 453.387500/1 | -131 | NFM | 1 | 00:00:00 | 07/03/24 16:35:52 | 07/03/24 16:35:53 | New System Saved | Department: 1 | 453.387500MHz | Conventional | CAP | Custom 1 | 0 - 0 - | ||
| CC 1 | 453.387500 | NFM | 1 | 00:00:00 | 07/03/24 16:35:53 | 07/03/24 16:35:54 | New System Saved | Department: 1 | 453.387500MHz | Conventional | CAP | Custom 1 | 0 - 0 - | |||
| 1139701 | CC 2 | 452.850000/2 | -125 | NFM | 1 | 00:00:02 | 07/03/24 11:09:13 | 07/03/24 11:09:15 | New System Saved | Department: 1 | 452.850000MHz | Conventional | DT3 | Custom 1 | 0 - 0 - |
