SC200: Is there anywhere to buy replacement rubber feet
zzdiesel
Kennett / Dunklin Co, Mo.
Where can I order new ones? Two of the rubber feet have come off of my scanner & evidently the dust bunnies ate them. I looked on Google It for them but nothing came up for this radio. Thanks in advance!
RandyKuff
Lorain, Ohio
RandyKuff
Lorain, Ohio
I thought you might of did a typo... Thought you ment SDS200...
I see an SC200 is a handheld unit...
You can snoop around on Amazon though... You might find something that will be small enough...
n5ims
Yes, Amazon has quite the selection of types and sizes (stick-on and ones that go on the case screws). My advice is to replace all as a set since the replacements never fit exactly the same as the originals so replacing all will prevent rocking.
dlwtrunked
Lowes (and may be Home Depot) sells "furniture bumpers" (Scotch brand). I have used these to put new feet on a lot of thinks. Get a pack of them and replace them all. (I have bought others from eBay or at hamfests only to have some of those cheaper ones "melt-down" in a couple years into a sticky mess.)
JD21960
ILL-annoyed
Home Depot and Menards have different sizes. I have larger ones on the bottom of my new PC for better air-flow underneath. Sticky on the bottom ... they're in the Hobby section of Menards ....
TailGator911
Silent Key/KF4ANC
Fairborn, OH
eBay is a good source for component rubber feet. I have ordered several sets for some of my desktop radios. I imagine some of them could be improvised to adapt to a mobile or hand held radio. Post a pic later when you have your final solution so we can see it!
iMONITOR
Silent Key
S.E. Michigan
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
I generally go with something like this:
I've found that black plastic or rubber feet have a tendency to melt and leave nasty gooey black spots on whatever the item was sitting on. These clear feet have never let me down.
Bob1955
Eastchester, NY
Uniden America Corp.-Parts Department at 800-297-1023.
K4RBT
I quit using the rubber (actually synthetic) because the leech plasticizer, the chemical that makes them soft, plyable. The ones on my BCD996T took the finis off of the shelf where it was placed. I do woodworking and found this information on a finisher web site. I only use felt ones now.Matching the finish on furniture is a pain, and I took the class at Woodcraft by someone in the business.
ecps92
Taxachusetts
Same thing, went with the Felt-Feet/Cushions generally used for Chairs. Tired of the rubber breaking down after years
dlwtrunked
Yep. As mentioned in my post, I buy the clear ones at Lowe's do not seem to go bad. Brands are Softtouch and Scotch. They look better than the cheap black rubber ones that either eventually fall off or "melt".
