MOGA
Before the City of Atlanta switched over to their digital trunked radio earlier this spring, I had excellent reception of their police and fire system from both handheld and base scanners that I operated from home and car, using portable OEM antennas. The sudden cold turkey of going from being in the know to knowing jack after my conventional trunking machines fell silent has been painful. Finally, I’ve acquired a digital scanner (GRE PSR-500) and got it programmed with a few Atlanta Fire & Police talk groups to start, just to get off the ground. I’ve been very much looking forward to once again knowing what is going on in my immediate community and fired her up after a quick last minute check of the firmware settings (current).
After about eight hours of listening, I am, uhh, not very pleased with the resulting experience. The audio is usually choppy and drops out regularly. It seems like once it gets going, it’s okay sometimes. But I miss the very beginning of nearly every transmission, and occasionally the entire dispatch is unintelligible because of how much the signal drops out. An earlier analysis of the system yields a signal that varies from 99% to 68%, with most of the samples coming in at 80% plus, yet the reception isn’t stable at all. The experiences of users in the thread PSR-500 Audio Cutting Out chronicle nearly the exact symptoms that I have, especially this remark:
Earlier today, I was out walking with my dogs along a culvert near GA DoD that is completely devoid of trees or structures for several hundred yards to each side to see if it would eliminate the wildly fluctuating signal strength. The radio was in a holster that, in turn, is attached to my backpack. I monitor the radio output using ear buds. I thought that if it is multi path that causes the earlier performance issues from inside the house, that operating in a wide open environment would present an improvement of reception. After all, a 320' AGL tower looms in the foreground from which I suspect Atlanta Public Safety simulcasts. It’s probably less than two miles from my home and always has City and State vehicles parked in the lot. Even if that is not the case, I thought that there may be a chance to see improvement due to not having any intermod around from stuff inside and around the house. Alas, no dice. The signal was as shaky and choppy as before when I was inside.
I’ve also played around with the settings as others have suggested. I’ve disabled multicast and delays. Disabled all priorities. Tried to attenuate the signal thinking that perhaps the front end was experiencing fundamental overload. Attenuating the signal results in reception that is so degraded that the scanner doesn’t even recognize one is there most of the time. What to do?
So I’ve come to ask folks that monitor the city of Atlanta system if they have similar experiences and if they’ve been able to mitigate them. Before I buy external antennas and cable and worry about guying up a mast on the roof, I am curious to know if the problem is not my radio or reception as much as an issue with the Atlanta system setup.
Thanks for any and all suggestions.
In addition to recently acquiring a new P25 scanner, I also am the first time owner of a VHF/UHF HT, MW/SW/FM portable, and HF rig. I also got a tech ticket last weekend. So you folks will be seeing lots more of my SN as I learn more about radio comms. I’m pumped to be diving into the hobby fulltime and to have a community with which to share my enthusiasm.
-MOGA
Watching the display on the 106 closely, the "T" appears when the audio cuts out, seeming to indicate that the radio is attempting to track the trunked system, even though it was already on a voice channel and decoding a programmed TG.
-MOGA
