I got mine today but I may be returning it. It seems to work fine on conventional vhf freqs. but when I enter my local PD's Motorola 880 mhz trunking system, the audio is badly distorted, raspy, scratchy and almost motor-boating and sounds far off frequency. Most channels are not copyable at all. I tried manually searching for a "conventional" 800 mhz signal such as an SMR and they seem to sound just fine. I have another scanner nearby that I put a low-performance antenna on as a comparison and all channels were loud and clear on it - but mostly not there on the 107. I put an 800 mhz antenna on the 107 and it slightly helped but not enough to make a difference.
Welcome to Radioreference Bill. Any chance that the database has the incorrect mode selected for the trunked system? What system was it, I'd be interested to see what the difference was between setting the frequency as trunked or conventional, when you say it sounded fine searching on an SMR frequency, but scratchy on the trunked mode.
Someone else posted that they heard scratchy audio also.
