What was the previous version of the database, an even 4, or something else?
Was the update easy to do?
For those of you that have a Pro-107 version 5 of the RR Database library in now available! You can download it via the Updates->Check for Library Update tab in the included Pro-107 software. It was updated Nov 30 2009.
Version 5 of the library is available! Check out http://forums.radioreference.com/ra...-library-version-5-available.html#post1207192
There is also a firmware and a software upgrade released 11/30 for the Pro-107.
Might as well grab all three while you are at it.
The firmware upgrade had the changelog listed below.
Where were the release notes, John?
I am running Operating System Microsoft Windows Vista Home Premium with service pack 2 and when I attempt to download the library update I get an error message "access violation at address 004ac7ef in module iscan.exe. Read of address 00000028." When I go to the library update tab it does show that version 5 is the current library. The program freezes at that point.
Also, when trying to update the iscan software I get an error message "error opening local updater file." I have turned off my firewall and virus protection but still get the same error message. Could this be due to the Operating system I am running or maybe a corrupted file? I did not make any changes to the standard format when installing the iscan software.
Can anyone help with suggestions?
Not sure what you mean about "logged into windows with an account that has administrator privileges". Can you elaborate about that requirement and how I could find out if I am logged on as such? Thanks for your time and patience.
I also found the release notes as a HTML document in my iScan folder.Where were the release notes, John?
Looks like someone posted a "Awesome" review on RadioShack.com RadioShack® PRO-107 Handheld iScan Trunking Scanner - RadioShack.com
Easy to use, made a playlist, like using an iPod...
I don't think a subscription is required.Another two reviews today. One says a subscription to scanner database is required, and the other says to read the owners manual.
