ISP frequencies
StanBud
I am looking for the Iowa State Patrol frequencies. When I open Freescan to upload frequencies is is asking for a TGID, I haven't found any listings with the TGID listed. Any leads or a copy of the listing with what I need would be appreciated. The advice to use Freescan was good, it worked nice to program what I have so far.
CT
In FREEScan, if you change the scanner to ID SEARCH mode. you will capture ALL TGID's heard on the system.
82996
Hope that helps!
StanBud
All ISP communications have moved or are in the process of moving to the ISICS. The existing analog frequencies will sunset October 2020.
Hope that helps!
I have not found anything like what you have posted. How did you get to that section?
CT
Open the file - click on "P25S" in the left window - Look at the "Trunk System Setup" Tab
83012
