nexus
Trainman111, if you use the link I provided, the one in the post right above your's when you're there watching the ISS move across the map in real-time, you will notice a red circle around the ISS icon. ANYTHING within this red circle means the ISS will be visible to you. So when you see the ISS icon moving in over your location and as long as your location is within that red circle you'll see a bright star moving across the night sky when you look up. It's about the same brightness magnitude as say venus.
http://spaceflight.nasa.gov/realdata/tracking/index.html
Richmond VA viewing times:
THE FOLLOWING ISS SIGHTINGS ARE POSSIBLE FROM FRI AUG 18 TO WED AUG 30
SATELLITE LOCAL DURATION MAX ELEV APPROACH DEPARTURE
DATE/TIME (MIN) (DEG) (DEG-DIR) (DEG-DIR)
ISS Fri Aug 18/09:40 PM 1 19 19 above N 11 above NNE
ISS Sat Aug 19/08:25 PM 4 74 33 above WSW 10 above NE
ISS Sun Aug 20/08:49 PM 2 22 22 above NNW 11 above NNE
ISS Mon Aug 21/09:12 PM < 1 10 10 above N 10 above N
ISS Wed Aug 23/08:22 PM < 1 11 11 above N 10 above N
Check back after Aug 30 to see a new set of dates that the ISS will pass over your city.
