Issue with LNA and IF in DSDPLUS Fastlane
rayneeny
Eastern Passage,Nova Scotia,Canada.
I have the latest version of dsdplus fastlane that i am using with an Sdrplay Rsp1a.
A year or so ago i had it working really well.
Today i have to manually adjust the LNA and IF in order to receive/hear signals but the settings don't save.
Is there a command i can enter into the FMPP.bat file to save those settings and bandwith to 12.5?
i enclose my really basic FMPP.bat file.
cg
Connecticut
According to the DSDPlus Notes & Help you would use:
-b-12.5
salado
Gloucester, VA
FMPP help summary:
Usage:
FMPP [options] Normal operation
FMPP -h Show help
Options:
-i<num> SDRPlay device number (1-255) [-i1]
-o<num> Output audio device (1-255) [-o1]
-o<port> Output audio TCP port (256-65535)
-A<num> RSP2 antenna select (1-2) [-A1]
-N<num> Enable/disable RSP2 notch filters (0-1) [-N0]
-L<num> LNA gain (0-8) [-L8]
-M<num> IF gain (0-59) [-M30]
-T<num> Enable/disable RSP2 bias tee (0-1) [-T0]
-f<MHz> Initial tuned frequency [-f99.9]
-b<kHz> Initial filter bandwidth (4, 7.6, 9.5, 12.5, 22) [-b7]
-u<num> Enable/disable unlicensed spectrum display (0-1) [-u0]
-z<num> Show zoomed spectrum (0-1) [-z1]
-n<num> Select noise filter (0-2) [-n0]
-v<num> Set volume level (0-500) [-v100]
-s<num> Enable/disable scanner mode (0-1) [-s0]
-wsl<v>.<h> Spectrum window location [-wsl50.50]
-_<num> Minimize windows at startup; bitmapped
-rc Role is trunk control/rest channel monitor
-rv Role is trunk voice channel monitor
