Issues with feed
emt_531
So I am currently running a Uniden 436HP for the feed. I don't like this thing as it's not user friendly. I am used to the banks. With that being said, when I move the audio cable to either of my Whistlers, the 1065 or 1040, the feed sounds terrible. Very low audio, etc. I do have the ARC software. I've changed the audio cable, adjusted the volume on both the scanner and ARC to try and rectify the issues. Tried a ground loop isolator as well. However, it still sounds terrible. Also in Radio Feed, I've tried to adjust the audio control as well. Any suggestions are appreciated.
rcool101
BUCKEYE NATION
I use a 436 also and use Radio Feed. My volume is set to 5 on the 436 and I think 8 on the Radio Feed. Also use a ground loop isolator. I am used to banks too. I programmed my 436, 536,100 and 200 like banks. Each Favorite List has one system and I give it a Quick Key. No Dept or site QKs. Just the Favorite List. Just hit a number and E. I put Conventional channels in 2 different FLs
