Italy PCN-60 With No Install Directions Help Please
blake25537
Could someone please explain how to wire/install this board? I tried but no luck and don't want to damage it or my radio. I'd be Grateful for your help.
P.S. I hope I posted this in the right area if not I'm sorry.
mastr
Since there isn't a "how do I install my illegal CB amplifier" forum, I suppose this area is as good as any.
rbomba
Check you tube for Snake Radio Customs. Get his contact info. Reach out to him and see if he will assist.
If he won't, your best bet is to just buy an external amp and have that as your set up. Is it legal? No, but so is doing 70 mph on a highway with a speed limit of 55....
Search NewEgg.com for RM Italy KL 203
Hope this helps a bit...
FiveFilter
Best solution: Leave the cover on your radio and get an Italy KL 203P. Connect it on the coax between the radio and the antenna. Test the SWR, measure the wattage if you're curious, and done! Not bad for 70 bucks or so.
brickson98
Wisconsin
I was going to say get the 203P as well, instead of the 203. The 203P has a SSB delay switch, unlike the 203.
