DSDPlus It's Been A Good First Week
S
simpilo
Guest
Thanks to everyone that helped me I now understand how to set-up DSD+ and FMP24 for P25, and DMR Con+ trunking on my own with little hassle. I may have further questions but as of right now I want to thank you all. It was very kind of you to lend an ear and your input. I did Tinker AFB rather well I think. Here is a screenshot. No Audio because I removed Pwave command from both batch files. Very customizable
slicerwizard
Toronto, Ontario
Very nice. BTW, you can drag the lower right corner areas of the event windows to change their height and width; you might want to make them shorter, but wider so the text isn't clipped and the windows don't overlap/block each other so much. You can also right click in those corners to adjust the text size.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Is there a primer anywhere to get started from?
The RR Forums :) Otherwise, no primer other than reading Notes.txt, Changes.txt, DSDPlus.txt, Trunking.txt as well as looking at the default .BAT files and FMPA/FMP/FMP2 CFG files. Oh yeah, and the -h switch available on FMP* and DSDPlus as well as the ? available in the main GUI of FMP* and DSDPlus.
I'm not being a wiseass. But I don't know of any other primer. Just do the light reading suggested above (sans the forums) and then ask questions in a new thread if ya get stuck!
