iview ps2 kvm switch
daleduke17
Bloomington, IL
Is it the kind of lime green one that Radio Shack sells?
If it is, try "Scroll Lock"+"Scroll Lock". I know that's how mine at home works, don't know if it is the same brand as what you need. When I get home, I'll look and see if I have the manual and what kind it works for.
N
N_Jay
Guest
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
this is usually right for 2 port models, 4 ports usually are alt, ctrl, shift then 1-4 (at least the 4 port ones I have used)
