Purchase the Diamond D130J discone if you have PL-259 connectors on your LMR-400. If you have N connectors on your coax, then purchase the Diamond D3000N discone and start enjoying the hobby. Taking off the top vertical element as recommended will reduce potential RFI from around 50MHz. Just put a nut on there in place of the vertical to hold things in place. Your "budget" may need to make room for notch filters to block things you don't want. For example, filters for FM Broadcast, nearby strong paging systems around 152 MHz, NOAA filter around 162 MHz and perhaps others like a low pass filter that blocks 500 MHz and up. Still, none of these filters may be needed. You will not know until your system is up and running and the filters may eat up your remaining budget. For now, put up your system.
That MP antenna is definitely/obviously not what you are looking for, nor is a J-Pole based on your posts in this thread. Get the Diamond discone, put it in place and start having fun. When you remove that vertical, either of those Diamond discone antennas are going to favor the 150MHz - 470MHz you are looking for.
** UPDATE **
If you want to blow your budget for just the antenna, you can order a Kreco D-150A for around $400 shipped. I am unsure if it would perform better than either of those Diamonds, but you could probably shoot at it from the ground using a shotgun with some birdshot...if you think it would see abuse like that.
** UPDATE **
Kreco D-150A Broadband Discone Base Antenna 150-1200MHz | eBay
Find many great new & used options and get the best deals for Kreco D-150A Broadband Discone Base Antenna 150-1200MHz at the best online prices at eBay! Free shipping for many products!
www.ebay.com
