What's up guys. Just for kicks I want to build a J-Pole for the railroad band, 160-161mhz., for scanning. Just to see how well it'll perform. I have no problem with the actual building of the antenna, except one part. The coax and such. What sort of coax would you recommend? I read all the tutorials online and all the pdf's and the helpful hints, but none seem to be persistant on what type of coax to use. Also, I need a bnc connector for my scanner hookup, I've never done connection installations on coax, is a bnc on a coax relatively easy to install? Also, I'm not sure if I want to solder the lead and shield onto the J-Pole, or use copper tube clamps to hold the wires in place so i can easily adjust if necessary. You know, just loosen, slide to where necessary for tuning, then tighten again instead of breaking the solder. Any help would be appreciated guys! If you need any more information from me to answer the questions just ask and I'll reply. Thanks again.
Ben
Ben
