Jacksonville fire- rescue
dlc423
Good afternoon. I have moved to Jax from Tennessee and I am trying to figure out how Jax fire and ems uses their talk groups. I guess what I am trying to figure out is what gets dispatched on what TG and where does it go from there. I hear calls going out on all types of talk groups. ALSO, it seems my BCD536hp is having a difficult time with the simulcast.
Just want to make sure I am up to speed and up to date on this.
Thanks alot!!!!
Jacksonville, FL
JFRD has a unique system where every single dispatch is broadcasted across A-1 through A-4. In a simpler form, you will never miss a dispatched call if you are listening to these talk groups. A-1 or EMS-East covers medical call traffic South and East of the St Johns River, A-2 is the main dispatch talkgroup. You will typically only hear dispatching and non-emergent admin traffic on this talkgroup. A-3 or EMS-West covers medical traffic North and West of the St Johns River. A-4 or Suppression covers small fire radio traffic and public assists, city-wide. JFRD units monitor A-2 on a typical basis. Once they receive a call, they will swap to the proper channel per either the location or nature of the call as stated before. To further explain this, When units are on A-3, they will still hear every call being dispatched city-wide from the dispatchers. The only difference is that only EMS West traffic will be heard between dispatches.
When a larger incident is dispatched, units are instructed to either switch to B-1, B-5, B-9, or B-13. If you pay attention to the initial dispatch, you will hear the assigned talk group. As an example, you will typically hear it in this order: "Fire District 1 Talk-group Bravo 1 residential structure fire for engines xxx ladders xx fires(chiefs) xxx rescues xx and a RIT assignment, blank address, all units responding talk group Bravo 1." If you miss the initial dispatch, they will typically repeat this without each individual unit within 20 seconds from the initial traffic.
I sure do hope this clears up some of the confusion. I, like you, was confused when I originally got to Jacksonville as well.
Bolt21
Spark Chariot Driver
Punta Piñal
ff2711, do you endorse the latest update to the db regarding the alpha tags and descriptions? I can't trust the JFRD db to be correct anymore since they've been changed multiple times in the past few weeks.
Jacksonville, FL
I personally do not agree with the JFRD database as some of the information is skewed. JFRD does not refer to any fire ground or expansion groups as C anything. The channels go B-1 through B-16. The main fire grounds are B-1,5,9,13. The announcement groups are B-4,8,12 & 16. You won’t want to monitor these as they are only used by command staff to make an announce over the previous 3 TGs. No traffic is typically received on this. Most incidents, unless major alarm, do not require anything past the main fire grounds (1,5,9,13). Those are what you want to tune in to. I hope this helps. I can clarify as needed
Bolt21
Punta Piñal
Ok, that jives with what I was thinking. The previous update seemed to provide some clarity, getting rid of the C-# tags. This newest one seems to have muddied it up again. Thanks so much for your input!
wsmoore
Jacksonville,Fl.
Old fleetmap with a typo in B-11.So tell me they don't refer to them that way. This came from the radio shop.
wsmoore
Jacksonville,Fl.
Oh guess you guys don't need the new updates so I'll just keep them to myself. Good Luck in your hunt.😂😂😂😜
Bolt21
Punta Piñal
Old fleetmap
Old. O. L. D.
Is it possible that they realized that the B9...C1 etc. tags didn't make sense and that they've been revised?
And BTW, when updates like this one don't make sense, maybe some evidence or explanation (such as what you provided after-the-fact) would be prudent. Then maybe you won't have to take it personally and "keep updates to yourself" when people simply wonder what's going on. Grateful for the info and explanation, but not the attitude. Peace out.
wsmoore
Jacksonville,Fl.
They just say the Tg to shorten the broadcast for the dispatchers.The B Flight names have been the same for about 20 years (2 systems now).Never have changed unless you can show me they have on the new Fleetmap. I don't know if you are new here or just didn't read the Alpha Tag. The System is not set up for what you think it should be.The Chief's and System Manager are in charge of it.
KevinC
The big K
Super Moderator
I'm everywhere Focker!
Just as a reminder...
