Jaguar 700p esk disable ?
salonorg
CARY IL
IF I HAVE A JAGUAR 700P AND IT HAS THE option 21 "EDACS Security Key " enabled in the string .
can this radio be used on a "regular" edacs system that does use the esk .
i noticed in programmer there is a option "edacs ip " and "edacs" . but from what i read edacsip is extended addressing esk ?
is this correct ?
Forts
Ontario, Canada
The ESK key needs to be loaded to the radio via a smartcard & keyloader. So no, just having that option in the radio doesn't make it work with systems requiring ESK.
Forts
Ontario, Canada
Or.... Are you asking can this radio be used on a system that DOESN'T require ESK (your wording is a little unclear). In that case yes, a radio with the ESK option can still be used on systems that don't require it (which is the majority of EDACS systems out there).
