Jaguar 725M to control radio 'B'
Steve_eo
I have a 725M that has a console head (IE not remote mounted). I'd like to be able to control another radio with the same head. Is that possible?
Anyone know what cable is required? Anyone got one they want to sell?
If this is not possible, I suppose I could get a remote kit (cost?) and then use the Macom dual radio control cable to control both radios via a single head....but obviously that would cost more.
-Steve
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
Whatever you decide, when you've done the research and know what cable assemblies you need, feel free to give me a call as I've got a wide variety of as-new Orion/725M/7100M control cables just sitting
here waiting for someone who wants them. I may even have an extra remote mount control head, and
hardware to convert a console radio to a remote mount radio.
Give me the cable assembly numbers you need and I'll tell you if I have it.
For test purposes, I've connected two control heads and a hand-held controller together on a single
radio, and it worked. I've got plenty of dual head cables.
Elroy
JungleJim
You'll need to convert the radio to remote mount and then get the cables for the dual band setup
ElroyJetson
I'm pretty sure I've got the necessary hardware to make that conversion.
Isn't it as simple as just removing the front panel assembly, installing a blank cover,
and using the control heads and cables with the radio's rear connector? And making
suitable configuration changes in the software?
Elroy
JungleJim
After you remove the head you need the flex ribbon cable, RIA board and back shell to make the head remote mount. A mount bracket might be handy too. Then it will just hook up to the control cable.
JungleJim
I'm sorry, in reviewing some documentation I see that my previous statement is not entirely correct, you should not have to convert your existing radio to remote mount. It should work fine as a front mount.
Steve_eo
So I can take my existing front mount 725 and plug in a remote mount radio and then I should be able to program the 725 to control both? I'm sure the 725 would be Radio A, and the Orio (the other remote radio) would be radio B?
I'll see if I have the cables to try that out....
-Steve
Steve_eo
Dang! I don't have two cables that have 37 pin connectors. I'll have to see what I have for documentation that might have the cable and a part number....or I'll have to build one if I can't find one online.
Steve_eo
After reviewing the documentation, what I want to do is known as: Orion Dual Radio Front Mount Installation Configuration and requires this:
Dual Radio Adapter Cable p/n:19B802554P10
Accessory Cable p/n:19B802554P1 or 19B802554P2 or 19B802554P7 or 19B802554P6
So, if anyone has a 19B802554P10 that they would like to sell please contact me.
Thank you.
-Steve
