Jaguar 725M
abqscan
DataBase Administrator
Moderator
AOA
Try holding down all of the buttons on the left hand side of the radio and turn it on. Thats how you get the LPE-200 into programing mode.
Erik
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Scott,
1. Install cables and equipment as described in the Hook-Up The Interface Module To Computer section and the Install The JAGUAR 725M Programming Cable
2. Start with the radio powered OFF.
3. Power the radio ON.
4. Perform a function in ProGrammer.
5. If the radio enters the programming mode correctly, "PROGRAM" will appear in the display.
sbkeith
Thanks to all:
It was actually my USB adapter on my programming cable. The driver was incompatible with the Programmer software. Again, thanks....
Liberator
Please note that the Jaguar 725M and M-7100 series mobiles DO NOT display "PROGRAM" like the Orion does when a programming cable is attached. The display remains dark with no indication of programming mode until you read or write to it. Did you know that you can bulid a cable for the Orion / M-7100 / Jaguar 725M that does not require a RIB! It's direct to the COM port...
