Jaguar Battery/Charger Question..
Forts
Ontario, Canada
Hoping someone can shed some light here... I picked up a Jag & charger, but it didn't come with a battery. Bought a battery online (which arrived today) but when I drop it in the charger... nothing. The charger is a BML 161 59/1 Universal Charger with a Jag sleeve in it. Battery is a BKB 191 210 NiMH. Is it possible that this charger will only do NiCD and not NiMH?
Forts
Ontario, Canada
Actually.... the more I read, the more it looks like this is the case. Geez I can buy a new Tri-Chemistry charger cheaper than a NiCD battery pack.
I have a OEM charger (NiCd/NiMh) .... from Macom, and it is the biggest piece of junk I have ever seen. It will not work with my NiCd or NiMh batteries. So .. I just use my Maha charger to charge my batteries. So ... I would be careful which charger and batteries you get as I have had poor success from the OEM chargers.
I know I am not the only one having problems .. as one of my friends has problems with his OEM charger too.
Oh .. I was going to tell you can tell if it is a NiCd charger only .. or NiCd / NiMh.
If the cord that goes to the charger from the wall has 3 prongs / connections (like what you would see on a pc) on the charger... it is NiCd. If it has 2 (smaller plug) it is NiCd / NiMh.
Forts
Ontario, Canada
How are you charging with your Maha charger? (I've got one of those as well). Good info on checking the cord type.. This charger does indeed have the 3 pronged connection. I ended up buying a 3rd party tri-chemistry charger, so hopefully that will do the trick.
So that would mean you have a NiCd charger .. and won't charge your NiMh as you have already seen.
Re the Maha charger ... I am using the MH-C777PLUS-II. It works very well with battery packs, but I see that it may be a discontinued item.
I think that you made a good choice by going with the 3rd party charger.
