Muxlow
Super Secret
I have a Jaguar P7100IP
Trying to read the radio and getting some issues
I have 2 different cables. One for the LPE/Jaguar that reads my 700P's fine and im sure works with the P7100 aswell.. And i also have a cable specifically for the P7100
When i put the radio in program mode. Holding the PTT and both side buttons the screen goes blank as it should. In programmer i have the correct com port and radio setting.
Read the radio and i get
Radio not in program mode and/or not initialized. Reconnect Radio
On the screen on the P7100IP after i get this msg in programmer it shows PROGRAM Self Test
Any idea what the cause of this is? The Revision menu is dissabled but im rather sure it was programmed with R18 or older.
Iv tried to make my own pers file and load that in and get the same error.
I read someplace i need to update the radio code to a newer one. It fixes something with a pin needing + power to a pin that the rib box provides and the ribless cables do not and that is the issue?
Any one know what the problem is here? Or could it be i just need to upgrade the radio file to fix the issue
