SkyPager said:
That's how I would do it. Two vehicles similar to Road Runner, one in front one in the rear would generate a moving RF bubble. Assume that they would generate broadbanded signal. (DC-daylight). What I don't know about jamming is would the signal be randomly modulated or just a carrier?
Two points to ponder cell phone bands differ in many countries. In Japan they are 935 MHz. Don't know about Spain.
Also simple is sometimes better. An amplified garage door opener would work just as well.
Well if that is how you would do it, I am glad you are not in charge.
If you just generate noise, how do you know if you have generated enough to overwhelm the intended signal?
If you try to block all frequencies, how far outside the "bubble" will you also be causing interference. What about other public safety frequencies?
If I had to guess, I would say;
1) the reporter did not understand what he was told, or was lied to intentionally, or the person taking to him did not know what was going on.
2) if they do have the blocking equipment, it is the same systems used other places designed to specifically block cellular (I think by looking for control channels and generating a signal designed to prevent a handset from synking with the data)
3) probaly won't use it, and it would probably be ineffective if they did. (for lots of reasons, like the bad guys using Nextel, or other non-cellular systems)
